Home Forums Printing Discussions Roland Printers SP300 Printing Black and Grey Shades – help?
  • SP300 Printing Black and Grey Shades – help?
    Posted by OwenTaylor on 31 July 2008 at 07:53
    Good morning everyone,
    I’m trying to print on some MD5 Matte white and the image is made up of blocks of colour – shades of grey and solid black. I am using the MD5 Matte colour profile from Metamark in high quality and the greys are printing perfectly, in fact I have never had greys come out so smoothly before. The only problem I’m having is with the black.
    The black just isn’t dense enough – next to the other greys it looks grey also. I have tried creating a rich black by adding up to 40% of C and M but it still looks ‘very dark grey’. I reprinted using various colour management setting including US MAX and Sign and Display. US MAX gave the result I wanted for the black but all the greys came out horribly grainy.
    Is there a way of boosting the density of the black only?
    Edit – sorry forgot to add. I’m creating the EPS file in Illustrator CS3 and ripping with versaworks (obviously) 🙂
    Please help! I’ll look forward to any advice…
    Many thanks, Owen
    Stephen Morriss replied 17 years, 4 months ago 9 Members · 13 Replies
  • 13 Replies
  • Mark Nihotte
    31 July 2008 at 09:54
    Hi Owen
    We usually use japan max to get better greys, but that is with our own profile…probably worth a go though. To get true greys, we have found the only way is to convert the black and grey to greyscale and use Japan max – is sometimes a bit hit and miss if there is also colour in the print as you are trying to make the machine print conflicting processes.
  • OwenTaylor
    31 July 2008 at 10:10
    Hi Mark, thanks for the reply. The greys arent really true greys, they are cool greys 5% C with various % K. There is also a small logo on the print with colour in it so I need to print full colour.
    I’ll try japan max and see how that works out.
    Does anyone know if there is a way of printing twice in the same place – say create two files one with the greys/colours in it and one with the black and print using a different profile for each?
    Thanks, Owen
  • Adrian Yeo
    31 July 2008 at 11:04
    Hi there. there was a thread in the Uniform section a while back about replacing spot colours. Seems to do the trick! 😀
    have a read
    http://www.uksignboards.com/viewtopic.php?t=24051
  • OwenTaylor
    31 July 2008 at 12:23
    Thanks for the link!
    Ok i made sure that black printed as 100% black using the ‘special colors’ feature in Versaworks and I managed to get a more solid, true black which is great!
    The black is still not as dense as I would really like – which is what I get from the US MAX setting. It’s just a shame that the colours/greys come out so terribly grainy. Has anyone else had this problem with grainy colours on any profile?
    31 July 2008 at 12:34
    what res are you riping the file at as that has i direct affect on the output also the number of printing passes.
  • OwenTaylor
    31 July 2008 at 13:23
    Hi Chris,
    I’m ripping at high quality 720×1440
  • Gavin MacMillan
    31 July 2008 at 14:46
    I’m having a mess with this just now but…
    when I export a file (eps) from corel using 2 rgb colours the ‘convert special colour’ box is not highlighted. I’ve set them up as per the versaworks help guide…
    Any clues?
  • OwenTaylor
    31 July 2008 at 15:09
    you have to create a special colour setting first.
    Edit>special colour settings
    then just save your file somewhere and click ok. you might have to re open the file with versaworks to get the option to work. then just click ‘details’ select your special setting and check the box.
  • Gavin MacMillan
    31 July 2008 at 15:55
    Hi Owen,
    I’ve done that but it’s still not happening. On the plus side I’ve found another way to do it from the signlab website, my head’s fried but I’m just about to print a job I need for Monday!
    G
  • David Crocker
    8 August 2008 at 21:34
    Hi there,
    Why dont you use the Density Control setting in Colour Management…
    You’re using Versaworks yes?
    8 August 2008 at 21:45
    if you have no colours to print, why not just bypass the icc output?
    that way the rip will just print with black?
    dont know if I’m right, but thats how I did my Breadstall print, which was a greyscale tiff,
  • Simon Polakof
    9 August 2008 at 12:04
    Hi!
    I thought just occurred to me as I was reading the different post. What is that you mean by the black not coming as dense as you would like? We used to have that problem before but did the spotcolor replacement in the rip and now things work perfectly! My thought was that it may depend on the fact that you are using a mat media and thus will never look as dense as it does on say a coated print media. Try printing the same job on a piece of coated media and see what different results you get.
  • Stephen Morriss
    9 August 2008 at 12:33
    I’ve just had a similar problem with an rgb image that I added a black outline to in Corel.
    I then exported it to eps and when printed the rgb image black was very dense black while the vector outline black was more like a dark grey.
    It wasn’t a problem in this case as it was just to allow for the cut outline being slightly off but it may be a problem later if I’m trying to match the black in an image.
    They both looked the same on the rip screen, Roland Colorip.
