Home Forums Printing Discussions Roland Printers SP 540 – Colors
  • SP 540 – Colors
    Posted by Terje Fjulsrud on 18 September 2007 at 11:48
    Hello
    I am new to alot of this and my question is about color.
    I use versaworks and corel draw. Versacamm 540
    I printed the roland color chip thing on normal quality.
    I also printed it in high quality and the colors are not even close!
    I also need to import a color swatch in corel? is this file located in versaworks folders?
    I guess i need help with the whole setup..corel –>versaworks
    There are allso alot of options when exporting to eps, postscript and
    apply icc profile..what does this do and not do??
    – Terje
    Terje Fjulsrud replied 18 years, 3 months ago 4 Members · 12 Replies
  • 12 Replies
  • Jason Xuereb
    19 September 2007 at 08:41
    Different quality settings = different amounts of ink on the media.
    I would see what settings your going to use and print out these charts for colour matching. You need to do them for every type of media your going to use. As they will all vary.
    You will also have to do them for every type of media and different profile settings if you change them for medias. It’s a pain in the bum but the only sure fire way you can do colour matching.
    I don’t use corel so can’t help you there.
  • Terje Fjulsrud
    19 September 2007 at 09:42
    Thanks I’ll do that.
    So if a customer has the cmyk values for their color, i cant just enter
    the values and print the same color?
  • Terje Fjulsrud
    19 September 2007 at 09:47
    i think I’m getting it now.. c100 m50 y0 k0 will look different on different medias and on different printers.. right?
  • Stephen Morriss
    19 September 2007 at 09:59
    Yes different medias have a different white point, some are very white while some can be quite Grey.
    I have Oracal and Hexis medias here and the Oracal looks Grey beside the Hexis media, the colours on the Hexis are slightly brighter as well.
    I’ve not printed out the colour charts using all medias and print settings and they are usually quite close, close enhough to give you an idea how it’ll look.
    Also while quite useful the colour charts don’t have all available useful on and I’ve generally found that it only gets me close to the needed colour.
  • Jason Xuereb
    19 September 2007 at 11:01
    That’s right. If they give you a colour to match you’ll need a swatch book and then you match that to your printed colour charts.
    I’m with Stephen I only have them printed for my main two types of media in one quality setting. I don’t really use them that much. Especially with photos etc.
  • Terje Fjulsrud
    19 September 2007 at 12:05
    Thanks guys
    I printed some of the roland swatch books, on avery mpi2000 with correct icc profile. Hi quality.
    The colors looks good. One "problem" :
    The onscreen color and the printed color are very far off..
    i know this is not easy to gett 100% but i am waaay off.
    When i look at the screen and see very light yellow, it prints almost orange!?
    any ideas?
  • Jason Xuereb
    19 September 2007 at 12:11
    Brightness, contrast, color balance of your monitor. The type of monitor you have ie crt or lcd. Makes a huge difference and monitor calibration is very difficult to get right. If you want 100% matching do the color charts and match to the output. Never match to something on screen.
  • Stephen Morriss
    19 September 2007 at 16:09
    Get a pantone huey or their next higher monitor colour calibration unit, they do make a difference.
    Did mine and thought it looked green at first but the output from the printer is close to the monitor.
    I seem to remember you can get a macro off the web to print the Corel swatches, it takes the colours and fits them to a page and adds the cmyk value, I used it for corel 9 a few years ago but can’t find it now.
    Do a google search on "corel macro print pallet" or something like that.
  • Terje Fjulsrud
    24 September 2007 at 09:17
    Thanks for the macro tips !
    Corel 13 Tools–>visual basic–>play
    Select global macros and hit run
    load the palette you would like to print. Hit ok. Done.
    I can now print all the default corel palettes 🙂 I guess i wont be buying
    a pantone swatch book when i can print my own 🙂
  • Ian Bingham
    24 September 2007 at 11:58
    dont forget to turn off colour management in corel, screen should be a bit closer,
    but rule is ignor screen and do a test print first!
    Ian
  • Terje Fjulsrud
    24 September 2007 at 12:23
    Thanks Ian.
    I did know about this function.
    When i have it on and with desktop printing profile, it actually came
    really close to my print. 🙂 🙂
  • Terje Fjulsrud
    24 September 2007 at 12:26
    ops.. i did not know about color managment…
