Home Forums Printing Discussions Roland Printers SP-300 Print/Cut not aligned
  • SP-300 Print/Cut not aligned
    Posted by Matthew on 16 November 2009 at 11:22
    When printing and cutting, the cut is missing the print by about 2cm.
    I have given the crop sensor and encoder a clean, and ran Env.match but not made a difference.
    Does anyone have any ideas on this as I am surprised at how far out of line the cut is.
    Thanks in advance
    Roy Roffey replied 16 years, 1 month ago 2 Members · 2 Replies
  • Lyle Knittig
    17 November 2009 at 22:02
    In the service manual there is a print and cut alignment. If there is no print cut alignment in the regular menu then you will need to get into the service menu and adjust. I don’t have the sp300 but it should be similar to most rolands. Do the print test and use the key pad to adjust the numbers.
  • Roy Roffey
    17 November 2009 at 23:03
    Hi Matt,
    Had the same problem myself this week funny enough, as lyle said you have to adjust this in the service mode, if you do not know how to pm me your number and i will call you tmoro..
    roffs
