Home Forums Printing Discussions Roland Printers sp 300 not printing magenta and yellow HELP !! Please
  • sp 300 not printing magenta and yellow HELP !! Please
    Posted by Kev Cringle on 23 June 2011 at 11:27
    Hi all I’m having a problem with my Sp300 its not printing magenta and yellow, these are my steps Ive taken so far but to no avail , 1st i checked print head and that was blocked so Ive removed print head cleaned with solvent and its OK again, so i put it back in printer and still no print on that head so i swapped the bales on the carriage board and then i lost the black and blue print head so Ive since replaced the carriage board and its still the same no magenta and yellow so i assume the carriage board was fine to start with so in my line of thinking the print head for magenta and yellow is not receiving the signal to print and that’s why the head blocked up in the 1st place ?, any advice would be welcome many thanks in advance
    Kev Cringle replied 14 years, 5 months ago 2 Members · 3 Replies
  • Kev Cringle
    23 June 2011 at 11:29
    ooppss should read swapped the cables on the print heads 🙂
  • Gabriel Cristian
    23 June 2011 at 21:39
    :). You have a (broken) fuse. It’s the F3 fuse on the main board. Replace that fuse and it will work again. Stop playing with the head cables. Those are"troubles" if you don’t put them back as it should. 🙂
  • Kev Cringle
    24 June 2011 at 08:52
    Thank you Gabriel
    Ill take a look at that many thanks
