Just go to heater config and keep knocking them down eventually the degrees will change to off on the display or you may be able to turn off from the rip.
When I cut normal vinyl I always turn the heaters off, when cutting laminated print work I turn the heaters on but only set on 40 I find it softens the lam and makes for using less cutting force, Rich
Please note:
