Home Forums Printing Discussions Printer Ink Some advice please on pigment/dye/uv/solvent inks
  • Some advice please on pigment/dye/uv/solvent inks
    Posted by Helen Butcher on 28 October 2011 at 14:55
    I am very confused (?) (?)
    I have been offered an Epson Stylus Pro 7600 and I am trying to get my head around the different iks I can use with it so I know which vinyl to buy.
    I have found the following info:
    quote :
    Without special drivers to change droplet layering, no printer can effectively utilize an ink for which it was not originally designed. A prime example is the Epson Stylus Photo 7600. The printer is sold as EITHER a dye ink version or a pigment ink version. The driver software is designed to work with the specific ink type. In addition, the service utilities (include physical components used to clean the printhead) must be designed to work effectively with the type of ink in use.
    My choice of vinyl for the application I need are:
    3M IJ40c-10/20 – designed for solvent and UV-Base piezo inkjet printing
    or
    3M IJ60c-10/20 – designed for piezo ink jet printing
    I am creating electronic device skins and although it will be indoor use they will be handled a lot so I plan to laminate the printed vinyl as well.
    Is there anyone out there who can relieve my headache and advise me on what ink does what and which vinyl I need with the 7600 printer???
    Helen
    Helen Butcher replied 14 years, 2 months ago 7 Members · 9 Replies
  • 9 Replies
  • Jamie Wood
    28 October 2011 at 15:04
    You won’t be able to use either of those materials on the Epson 7600. This is an aqueous ink machine – the dye ink and pigment inks are both water based. To use
    either of the materials mentioned, you will need a solvent, latex or UV based printer.
    You can get vinyl for the water based machines, but it is more expensive and not as
    versatile as the solvent one, and would definitely need laminating for your planned use.
    I think Warren used to use aqueous vinyl, so maybe he could point you in the right
    direction.
  • Warren Beard
    28 October 2011 at 15:08
    sorry quick reply as on my way out, do a search under my name for pigment based printing and there is a thread somewhere I put my old suppliers down, not sure if I still got them as have been running solvent only for 18 months.
    Warren
    28 October 2011 at 15:17
    since you last asked some questions i had a look in to what the main players are using. just out of interest before i get asked about some.
    the epson 7600 is a dye or pigment water based printer and will not print on to the IJ40 for instance.
    epson used to do if you can find a supplier a gloss vinyl for that printer but cant comment on its suitability.
    the machine that will do all you want for phone wraps is a roland bn20 coupled with a air release wrap vinyl and laminate that’s the material they seam to be using. (for the better dearer ones anyway)
    you need print and cut something like a SP300 will do the job but the output quality from the little bn20 is more like you want to sell + its got metallic colours for up selling.
  • Helen Butcher
    28 October 2011 at 15:32
    Thanks all
    Warren I shall find that post and read it.
    What do 3M mean with the different descriptions:
    or
    Are they really the same thing just the second one is an abbreviated description?
    I will absorb all this and make sure I get the correct equipment – I promise.
    I have a shopping list with all the correct equipment but I was hoping the Epson might save me a few ££ just while I get started.
    Helen
  • Andrew Martin
    28 October 2011 at 15:38
    As your going to laminate your vinyl the Epson will work providing you get suitable vinyl for aqueous (water based) inks.
    piezo ink jet printing applies to solvent or water based printers… it referes to the piezo print heads the print machines use.
  • Stafford Cox
    28 October 2011 at 16:18
    Hi Helen.
    The Epson 7600 is a wonderful little machine. It is a 24" water based (otherwise known as aqueaous) piezo (typically a fix head rather than a user replaceable ‘consumable’ printhead) printer that prints very high quality (1440dpi or even 2880 IIRC…?) but by todays standards, could be classed as a little slow. If speed is not important to you, then this will be a great printer for you.
    The 7600 is a pigment based printer and was only sold in it’s dye form outside of Europe. I’m pretty sure you can run the printer on either Matte black or Photo black, depending on what media you print on the most but to swap from one to the other involves flushing out a couple of the lines and refilling which can be expensive. I would choose one ink type and stick to it if I were you. Most people chose the Photo black option.
    You will need to print onto coated media such as Epson Self-Adhesive Vinyl Paper Roll (C13S041437) or similar and then laminate it for durability.
    I hope that’s helpful.
    Stafford
    28 October 2011 at 16:38
    Helen, the biggest problem you have is that you need a media which is conformable to cover the range of products you wish to sell. As far as I know there are no manufacturers of coated conformable media that you could use in a dye or pigment ink printer.
    I use to run an encad 850 which ran on the same type of ink you are asking about, tried everywhere to get a suitable media but as there is no great demand for it people just don’t make it. Even looked into coating media myself but that’s not really practical.
    Best bet would really be to look at the BN 20 from roland which would be ideal for the sort of work you want to do.
    28 October 2011 at 17:17
    Have you spoken to anyone like Business Gateway about your business plans Helen?? Might be worth seeing what’s available in your area. I remember you saying in another post that Disability has stopped you working. They might be able to help with some things as there are grants available to help if you meet the right criteria. Unlikely someone else in your area is already doing this sort of thing which normally knocks most grants on the head.
  • Helen Butcher
    28 October 2011 at 17:29
    Couldn’t find the post you mention Warren – if you can provide a link I would appreciate it.
    I think I am going to stick to the eco-solvent printing method and have the wider choice of media to choose from.
    Martin – I took my business plan to Business Link/Chamber Commerce (in same building) who loved my idea and threw all sorts of questions at me and were impressed I had all the answers. However, they admit there is no financial assistance out there at all – not even loans for start-ups and this is hitting start-ups hard. This difficulty in financing is what has taken me away from my original shopping list and to looking into cost-cutting ways to at least get started.
    Have looked into renting – which is possible and will give me the opportunity to get trading, test the market before committing to purchasing new equipment – that leaves me some time to also raise the readies to get the equipment I would prefer.
    I am spending the weekend mulling everything over and will have hopefully decided my path by Monday so I can move onto the next task on my long list! 🙂
    Thank you all for your input (once again).
    Off to have a hot bath with a cold drink now – enjoy your evening & weekend too.
    Helen
