Home Forums Printing Discussions Roland Printers Soljet xc540 printing problem
  • Soljet xc540 printing problem
    Posted by AG Martin on 19 August 2009 at 11:55
    Hi all
    Hope all is well
    im currently having a problem printing wall graphics
    were trying to print at a height of 2.2 meters in 4 parts so a total wall size of 2.2 meters by 5 meters. we are then mounting to 3mm foamex
    im tiling the artwork in verse-works and struggling to get the panels to marry up. they are out as far as 3 mm in places from length to length
    we cant narrow down if its the printer or even possibly the laminator?
    if any one has had a similar problem any help would be much appreciated
    kind regards
    Martin
    mod-edit no advertising allowed
    Jason Xuereb replied 16 years, 4 months ago 3 Members · 3 Replies
  • Andrew Ritchie
    19 August 2009 at 12:36
    could be the vinyl stretching during fitting.
    are you laminating the prints straight to the foamex or applying by hand?
  • Brian Bollard
    19 August 2009 at 23:52
    This is a common problem I have never been able to work out a solution to.
    There always needs to be a bit of fudging to line up panels.
  • Jason Xuereb
    20 August 2009 at 02:06
    A lot of things factor into it.
    Temperature in your print room.
    Humidity.
    The weight of the roll as the media is reduced on the roll.
    I have an XC and an XJ and the media handling on the XJ is a lot better in terms of tracking and pull etc.
