Home Forums Sign Making Discussions Vehicle Wrapping Solid colour vinyl or digital print – help required please?
  • Solid colour vinyl or digital print – help required please?
    Posted by Seun Aderibigbe on 9 February 2015 at 18:28
    Hi All,
    Can you advise the best course of action to way to do this job.
    Option 1. Solid colour vinyl which will mean using app tape (not sure how well r tape is around curves)
    Option 2. Digital print.
    Thanks for all you responses. :praise1:
    Seun Aderibigbe replied 10 years, 9 months ago 4 Members · 4 Replies
  • Simon Worrall
    9 February 2015 at 19:18
    Seun
    Option 2. No doubt.
    Simon.
    9 February 2015 at 21:29
    yeh i would do it in cut vinyl.
    it will be more tedious a task getting the application tape off, but will allow more precision.
    once in place as best you can. cut up into separate swirls and remove the tape laying in the graphic that isnt tacked down.
    sorry hard to explain without showing you. either way will work but i recon ide go option 2.
  • Gil Johnson
    10 February 2015 at 23:55
    I’m with Robert, cut vinyl will achieve a better finish. As he says it’s a trickier job but allows original white of vehicle to show through.
    Gil
  • Seun Aderibigbe
    16 February 2015 at 10:43
    Thanks for all your advice, went with option 1 in the end because the solid coloured vinyl would look better than a digital print also the white of the vehicle and the white of the vinyl are different. It took ages but it does look good. Thanks again for your advice. :thumbup2:
