Home Forums Software Discussions General Software Topics Software for Lidar LD-700
  • Software for Lidar LD-700
    Posted by soesantohenry on 17 May 2006 at 15:22
    Hello everyone! I am really new in business, I just bought Cutter Lidar LD-700, It comes with Artcut05 sofware, but I don’t like it, because I can’t import file from illustrator Cs. I draw using illustrator Cs.
    Is there any other cutting sofware that can import file from illustrator cs and which also support my cutter LD-700?
    thank you
    David Rowland replied 19 years, 7 months ago 3 Members · 5 Replies
  • Tim Shaw
    18 May 2006 at 09:41
    try saving your files from CS as illustratot version 3, I use the same software and have no problem importing file from CS1 or CS2.
    Also are you opening the file or importing it into your software, I guess you should be using import or place, usually NOT open.
  • soesantohenry
    18 May 2006 at 16:05
    Hi, thank you for the reply.
    I just tried it now but the lines still corrupt.
    What I did is:
    1. export to illustrator legacy EPS and click SAVE
    2. another windows pop up called "legacy EPS option" come up and I choose
    version: illustrator 3 EPS
    preview, Format: TIFF (8bit color)
    adobe postcript: language level 2
    3 Click OK
    Did I do save the correct way?
    thank you
  • Tim Shaw
    19 May 2006 at 08:49
    Think you need to be saving as illustrator legacy v3 NOT eps.
    Also the file you are saving should end in .AI. And remember to import / place into your software.
    You are only exporting the vector info, so the less info you are trying to get across the better.
  • soesantohenry
    19 May 2006 at 13:34
    Thank you for the explanation, i gave a try just now. I save my file in .ai version3.
    And tried to import it to artcut, but nothing happend, nothing come out.
    as far i know artcut cannot import .ai file
    thanks
    henry
    19 May 2006 at 13:40
    at the top of this forum, there is a "Search the boards" thing… type ArtCut and press Go… some other people with Artcut with similar problems.
