Home Forums Sign Making Discussions Neon, LED, Lighting SMP Sign returns
  • SMP Sign returns
    Posted by Richard Urquhart on 16 March 2010 at 21:55
    Hi all, got a bit of di bond that I’m going to face fix to a projecting bracket that’s on the wall already, industrial unit so face fixing will be OK. Now just thinking of running the SMP sign returns around the edge after fitting just to give the sheet a look of depth and to fill the return from the wall. I will not be fitting like a tray so these are just to make the edge 50mm when looking up from the ground, anyway to the question I see the adhesive is on the inner edge does this make fitting hard in one complete length, i.e does it stick one end and then cause problems getting the trim on straight?
    thanks Rich
    Richard Urquhart replied 15 years, 9 months ago 2 Members · 2 Replies
  • Kevin Flowers
    16 March 2010 at 22:32
    Rich
    depends what adhesive you use, the trim itself does have any on. You can use VHB tape or a building adhesive i normally mount it on the bench lot easier even if you aren’t using it to mount the sign.
  • Richard Urquhart
    17 March 2010 at 09:58
    Thanks Kevin, was going to fit the 3 sheets and then trim on site, would slip on nice with building adhesive but wont stick right a way, not sure now !! or do I just leave it and stop making work for my self.
