Home Forums Sign Making Discussions General Sign Topics small locators – supplier?
  • small locators – supplier?
    Posted by steve on 22 March 2006 at 04:18
    Hi everybody have a little problem we make our own flat cut letttering and increasingly we are being asked to fit locators to small cap height text ie under 100mm. Can anyone assist by letting me know where i can purchase a snap on type of fixing with a sub 10mm footprint i would be pleased to hear from anyone who has found such a product.
    (mod-edit)
    Vince Francis replied 19 years, 9 months ago 6 Members · 6 Replies
  • George Elsmore
    22 March 2006 at 08:02
    Hi, I dont know if these guys do something along those lines?
    George
    doh! here is the link
    http://www.snapfix.co.uk/
  • Glenn Sharp
    22 March 2006 at 08:16
    Steve,
    It is a problem we have come across aswell – we haven’t be able to source a locator with a small enough footprint either. On small letters we have been glueing clear acrylic rod to the back of the letters & siliconing the rod into the wall.
    I would be very interested if anybody is using small locators though
  • Nick Williams
    23 March 2006 at 11:40
    just an idea someoe mentioned to me was that they would grind down the sides of the foot to within under what is visible leaving the foot on behind the lettering
  • idgni
    23 March 2006 at 17:46
    we use a home made system that works very well, total diameter of 8mm and very cheap
    get some 50mm bolts M5 and get some lorry air pipe (local garage will be able to help) in white 8mm diameter. cut the pipe into 20mm sections to use as a sleeve over treads of bolt.
    place head of bolt onto a small drop of TA431 2 pack Glue or similar. and wait to glue sets.then mark template
    bore the wall with a 7mm sds bit approx 35mm deep and fill hole with GRIPFILL or equivalent.
    BOB UR UNCLE! JOB DONE 😀 😀
  • Lorraine Clinch
    24 March 2006 at 09:34
    I’ve just measured the small fittings from Snapfix, the base is 16mm diameter-sorry!
    Lorraine
  • Vince Francis
    29 March 2006 at 18:25
    Have you tried FKMoore in Ramsgate. They do a small locator, but they are brass though, but can be glued on
    Vince
