Home Forums Sign Making Discussions General Sign Topics slotting system for removable signs
  • slotting system for removable signs
    Posted by Colin Hibbitt on 31 January 2009 at 20:44
    Looking for a system which we need 18 slots onto a 8×4 so the customer can change boards which slide very easily ie: some sort of tracking which takes 3mm diabond plates 24"x4" plates
    also a slotting system which take a 24×18" plate mounted onto 11swg ali which again can change with diabond panels
    colin
    Gordon Jones replied 16 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • David Rogers
    31 January 2009 at 20:56
    I have on several occasions used ‘wall board’ edging strips.
    Several companies do a satin anodised aluminium channel that takes 3mm perfectly…and it makes an ideal runner / slider.
    (Vaguely a square ‘J’ shape)
  • Colin Hibbitt
    31 January 2009 at 20:57
    dave who would supply this
    colin
  • David Rogers
    31 January 2009 at 21:01
    Can’t remember who I got it from offhand – but somebody like this.
    http://www.hart-wholesale.com/alum.htm
    (just from a web search)
    Similar to profile A32…but without the ‘wedge’ as material will / may jam…but THEY don’t do it anodised. (Only an issue if cosmetics are a major issue)
    I THINK I bought it from Righton last time – but not 100% sure.
    http://www.righton.co.uk/product-sectio … heCatID=14
  • Graeme Harrold
    31 January 2009 at 21:05
    Have a look at this……….Slat System
    What you are looking for is a Slat System, and there are a few around, most of the ones I have seen are male/female systems rather than slide in dibond…..
    I did one before, but it accepted 0.8mm panels that I got from Mastergrave
  • Colin Hibbitt
    31 January 2009 at 21:19
    hi guys – i think the master grave is the way to go – what i got is a recycling site which needs to swap the plates on a daily basis – so we have a 8×4 Ali(11swg) backing board mounted onto post with 18 slots (bays 1-18)approx 18"x4" with individual name plates which need to be interchangeable with different diabond panels showing the customers different recyclable products everey day
  • Graeme Harrold
    31 January 2009 at 21:57
    just remember to think outside the box!!!!! Although there is only two widths of profile listed, I sliced the 50mm profile to get a 100mm header board in place.
    What the Mastergrave one does is creates two side rails and a base into which you drop the preloaded profiles and might not be as rapid changing as simply sliding something in from the side. The one I did was for an accountant to display their "Ltd" accounts.
    Foolishly I didnt take a pic of the finished product 😕
  • Gordon Jones
    1 February 2009 at 19:38
    spandex do a good system with 7 different widths
    http://www.spandex.com/UK/Sign_Systems/ … Slatz.aspx
