Home Forums Printing Discussions Roland Printers Slight streaking – magenta
  • Slight streaking – magenta
    Posted by Jason Davies on 27 June 2015 at 17:05
    Equipment – Roland VP and Metamark MD5
    We seem to be experiencing slight banding with a deep magenta print when run in normal print. This is new and can only be seen in a magenta colour. Run a nozzle test and it seems to be firing on all nozzles and when printed in best mode there are no issues although this takes sometime.
    Heads cleaned, power cleaned etc.
    Any suggestions greatly appreciated. We do have a maintenance contract but if I can resolve it would just save us a lot of wasted time over the next few days.
    Jason
    Jason Davies replied 10 years, 6 months ago 3 Members · 5 Replies
  • Stafford Cox
    29 June 2015 at 11:20
    Man, I wish my contract customers would try and finds the answer to their problems before coming to me :lol1: :lol1:
    It’s weird how it’s only in a certain mode. Have you tried using a different ‘normal mode’ profile? If it’s the same on two different profiles then I would look at fine tuning head calibrations. If it changes with the profile, there’s your answer 🙂
    Stafford
  • Jason Davies
    29 June 2015 at 18:10
    Thanks Stafford, tried another Metamark profile but the print until recently has been perfect. It’s odd, it’s almost as if not enough ink is getting through when you flood coat magenta, all the other colours are fine. As you know there are four separate heads on the VP. Should have an answer tomorrow.
    Thanks for the reply, much appreciated.
    Jason
  • Stafford Cox
    30 June 2015 at 09:50
    No probs.
    Let us know what it was in the when you get chance.
    Stafford
  • John Hughes
    1 July 2015 at 21:50
    Try turning the heat down on the bed. We been having the same problem with greys and that helped.
  • Jason Davies
    2 July 2015 at 05:45
    Thanks for the advice, we had a new head fitted yesterday. Even though we were having a 100% of the nozzles firing the head had just worn out and when you looked at the test print the nozzle lines had slightly lost their shape. In all fairness this was the original head which has lasted 9 years so can’t complain.
    All up and running now. We still have the original Yellow and Cyan heads so I guess they will be due for replacement soon.
