Home › Forums › Sign Making Discussions › General Sign Topics › SKIP FOR HIRE – HI VIS PAINT, ANY PROBS LIKELY?
Posted by Brian Little on 1 September 2005 at 07:06hi folks . ive got a skip to letter. problam is if indeed it is a problem is the customer is painting it in hi vis paint . ive never seen it before but was wondering if anyone else has and if i would have probs with vinyl adhesion . if so ill just paint it on
Regards Brian
John Singh replied 20 years, 3 months ago 5 Members · 10 Replies -
Hi Brian, best just make some stencils and let him paint them. I produce magnatic ones for this purpose, I have seen other people try vinyl and they just come off due to the bashing that skips get.
Dave -
Hi Brian
We have used hi-vis paint before, the one we had was produced for marine applications, really expensive about £100 per gallon, only ever painted over this, using one shot.
As Dave says, vinyl may not stand up to the abuse these things get.
Andy
hi Dave & Andy ….sorry i never fillied in the blanks ….what i should have said is that this Skip belongs to a scrap matal dealer and its going to be a showpeice at there offices . There going to suspend it on a massive steel rig just as you drive in the gate so it wont get any bashing that the usual skip gets
Regards Brian
Brian
Can’t see any problems in using vinyl in this case then. But I think I would still use one shot simply because I have used it many times on hi-vis paint and have never had any problems.All our jobs using this were support ships for the north sea oil rigs, and they do take some hammer, but never had any issues with the paint fading or coming off.
Andy
Cheers Andy 😀 …traditional method it is then .just one final question does this hi vi paint have a sort of rough finish to it
Brian
Brian
The one we used was a smooth finish, has a soft feel to it though.
Hope it’s not to bright a day when you do it, if it is you will need your sun glasses 😎
If its a showpiece then why not signwrite traditionally?
It’ll look the bizJohn 😀
Hi all
Hi-viz paint is normally laquered over, the process is matt white base colour, fluresant colour and then laquer normall vinyl should apply excellent to it. i apply vinyl to working skips from mini to roll on/off binsKev
I know what you’re all talking about now
It’s flourescent paintI’ve actually signwritten in this stuff
Great bit letters ‘n’ allJust as Kev says base coat then the flourescent then the UV protection laquer
Shouldn’t be any different from ordinary paint so vinyl should apply alright
