Home › Forums › Sign Making Discussions › Neon, LED, Lighting › Single Sided Di-bond
Posted by David Rowland on 27 November 2009 at 14:34Has anyone come across single sided dibond? (stainless looking one side and either white or black on the inside)
I have also a scrap bit of White inner dibond material? anyone know that one?
David Rogers replied 15 years, 10 months ago 9 Members · 10 Replies -
The single sided stuff you are talking about with white on one side and silver the other sounds like the hoarding grade material that amari do
G
got a sheet the other day from europoint hoarding grade mate
Hi Dave
The white cored ali-comp sheet is from Amari, thinks its called "E Bond Premier"
Macky -
Are you looking for the Stainless finish as the front?
Im sure Righton do it, I had some samples sent a few weeks ago.
Are you looking for the Brushed Stainless Steel "look" if you are it is referred to as "Butler" Dibond.
i am looking to fabricate something but the sheet needs to have one layer of metallic stainless sandwitched to an inner core.
basically single sided dibond -
sounds alot like hoarding board which i use all the time. Dont quote me on this but i think that diabond can be bent and hoarding cant be if for example you want to make a light box or something. Best to confirm that with the supplier though. I use hoarding as its cheaper and for flat panel work its great!! :lol1:
quote Dave Rowland:i am looking to fabricate something but the sheet needs to have one layer of metallic stainless sandwitched to an inner core.
basically single sided dibondSo it’s just got ONE side of metal – the other (core / backing) as the polyethylene backing?
Think you’re going to struggle there.
As said – ‘butler’ finish is probably as close as you’ll get. If fabricating – I’d avoid the cheap stuff – it’s useless for anything large – but just about workable for very small projects.
