Home › Forums › Printing Discussions › General Printing Topics › Silvers to print?
Silvers to print?
Posted by Ryan Fairweather on 28 September 2006 at 11:38Is it possible to create metallic colours in corel draw such as silver?
I would like it to appear as close as possible to silver once printed? Is this possible?
thanks
Rodney Gold replied 19 years, 1 month ago 4 Members · 7 Replies -
Hi Ryan,
A trick I use when trying to emulate Gold or Silver on my large format is to print about 40% Black for Silver or the Gold colour in Corel but print with the head in it’s highest position, it produces a speckled texture that almost looks like the light is reflecting off a metallic surface. Of course it’s only good for large format printing and might not work on every printer but thought it worth a mention.
Regards, Paul.
Thanks for that, i have already discovered with some test prints exactly the same thing.
Great minds think alike eh? 😀
Yeah I guess, although I’m sure my missus wouldn’t agree 😀
The metallic PMS colours 8003 – 8321 also give some good results.
dont rule out printing onto silver vinyl… it has interesting results.
Such as?
Does the silver come through the print, providing a metallic look?
it can do… however i dont want u going selling ‘yes it works’ to your customer without you seeing it for yourself.
Yes, it does give the inks a metallic look , and you can vary the metallic look with your inkloads as well as the type of substrate you print , the best is mirror silver for this.
Some of the mirror Metallics wont accept inks , but there are 2 workarounds
1) spray artists fixative on the metallic
2) Overlam the metallics with Clear and print the clearAnd a 3rd one , and that is to buy a coated mirror vinyl (we get ours from Starrex/X-film
I would also limit this to small stuff if you printing mirror , big stuff has a sort of wavy look due to the vinyls , ie the reflective surface is not dead flat.
You can actually print on other substrates for this with different properties
Rowmark make a substrate called laserlights , it has a wonderful shiny brush finish and is self adhesive and can be vinyl cut , its a mil spec material with extremely strong adhesives and the silver and gold can be printed very nicely , expensive and small sheets , but the look is wonderful , fantastic for small durable decals that need a bit of thickness.
