Home › Forums › Sign Making Discussions › General Sign Topics › Signs for a Zodiac
Signs for a Zodiac
Posted by Phill Fenton on 11 September 2002 at 11:55You’ll be needing a water sign for that one Gray 🙄
Sorry – But I don’t know the answer to this one.
signscript replied 23 years, 3 months ago 4 Members · 4 Replies -
what about that lorry curtain vinyl, it may be more up to the job, when you think that lorries get steam cleaned and what not surely it can stick to a dingy
ANDY
Hi Gray, I think you could be on a sticky wicket with this job !!!
You really need to know if the dingy is to stop inflated or does
your customer inflate it as required ? If is stays inflated then I think PVC
ink will do the job – but if it is inflated when used then you could try to locate the ink that is used to print balloons, it might work ?
The other problem is the type of water the dingy sails in ? fresh water doesn’t present a problem, but sea water is very searching and could cause more problems. I would leave the job to one of your competitors
and let him have the headache !!!!!!!, Brian. -
I don’t know the answer to you problem either Gray !!
Just a thought though, have you tried to contact a company that makes these craft? I’m sure the manufacturer cant be that hard to find and they should be able to tell you. The RNLI use these craft over here and I am sure I have seen some of their inflatables with graphics on, do you have something similar over there? -
APA TRUCK VINLY gray its the only stuff to use, banner vinyl just comes off after a few weeks, especially if the craft is going in salt water
