Home › Forums › Software Discussions › Signlab Software › signpal to a.i conversion
Posted by Derek Heron on 28 October 2008 at 12:21Hi all
i have a jaguar signpal cutter with signpal master software
it has crashed this morning
but i have all customer files backed up
any ideas how to convert them all to a.i eps files
so i can cut them on the cadet which runs with signlab 8 till i get this up and running again thats if it will
😥derek
Nigel Pugh replied 17 years, 1 month ago 3 Members · 9 Replies -
Might be a daft question Derek, but are the files in signpal format?
and have you tried importing them direct to signlab?Peter -
Derek if your SignPal software is not working and all your jobs at the time were just saved then that means they are Flexi files and so only Flexi or SignPal software I believe will open them.
Any chance of explaining what has "crashed" is it the software or pc.
Nigel
Hi peter
yes they are in signpal format saved on disc on friday gone Phew!
but unlike most files which just drag into signlab these dont
if i can get this up and running
it means i am going to have to go through each and every file and re save as an a.i.
or am i missing somethingDerek
hi nigel
just missed your post
its the pc thats crashed
its done it before its an old pc running win98! i had a new pc built xp but the software wouldnt run tried all ways inc a couple of calls to techis
in the end went back to fixing the pc with 98 and its been chugging along
until now.Derek
So it won’t work with XP, your SignPal must be version 6.0 , 6.5 or 6.6 that makes things tricky.
I think you will need to get the old pc running again and then export all your jobs out as a.i. files.
Nigel
hi nigel my version is 7.0 and should be ok
with 95/98/200/NT/AND XP
its the master version
but it wont work
Derek -
V 7.6 was the version to be fully compatible with XP, V 7.0 did have problems with XP, when the service packs came out and with newer versions of XP.
When XP came out, initially there were patches for V 7.0 but with the updates happening to XP more and more problems came about for V 7.0
Hi Nigel
its just been pointed out to me that the box is marked with compatible with 95/98/2000/NT/ XP
and its actually not because it wont workWhen XP came out, initially there were patches for V 7.0 but with the updates happening to XP more and more problems came about for V 7.0
Any ideas who i should contact for help on this
Derek
Derek, give our tech dept a call 01827 300500 and ask for Steve, if anyone can help then it is him.
But as mentioned before if your XP has been updated via service packs then it may not be possible to solve.
Nigel
