Home › Forums › Software Discussions › General Software Topics › SIGNPAL JAGUAR
SIGNPAL JAGUAR
Posted by Alison Falzon on 9 November 2004 at 20:22Has anyone got one of these plotters?
Are they recommended, or should I KEEP AWAY!!!!
Opinions greatly appreciated!
Alison Falzon replied 21 years, 1 month ago 7 Members · 7 Replies -
Hi we run a signpal ultra 1320s, the jaguar I believe is one up from this.
had it 4 years and never a problem, they come from graphityp, and think they are rebranded igc.
Peter -
Not used one but Grafityp decided supply these machines when the Ecom range finished. I have never heard a bad report. The latest news letter from them has a 610 machine in at £999 cant remember if thats with or without the governments fine ooops vat on.
I’ve had one of these for two years now, and I cut a lot of sandblast material wich is heavy duty.
Never had a problem with it, and would highly recommend it :clap2: -
Peter the Jaguar replaced the Ultra just over two years ago, neither machine is rebranded they all come from the same manufacturer, the machine for £999 is the entry level Puma range again from GCC
I’ve got a SignPal Jaguar II 101, good machine – incredibly fast when you want it to be 1530mm per second – that’s 5 foot per second!
It cuts letters down to 3mm high, has a tangential emulation mode for ‘straight line’ work, 4 programmable tools so no having to reset everything every time you change vinyl, I can’t fault it.
I cut all-sorts from cast to reflective in the Jaguar and it handles everything I throw at it.
I would certainly recommend them to anyone.
Mark
I use a Jaguar II 101 as well. Went down to Graphityp and was impressed at the speed and ease of use. I had used a Mutoh previously, but didn’t see the need to pay that kind of money for my own machine. Also bought SignPal to run it, that’s pretty good too (although the machine does come with a basic cutting program).
hope this helps.
Tony
Thank you everyone for your feedback.
You have helped me enormously to make my mind up!
Ali 🙂
