Home Forums Software Discussions Signlab Software Signlab re-setting font groups
  • Signlab re-setting font groups
    Posted by Phil Veitch on 9 February 2011 at 09:05
    Hi guys, our signlab is resetting the font groups, every time we open up, all the font groups missing and we have to reinstall..
    Any ideas??
    Phil
    Ray Wilcox replied 14 years, 10 months ago 1 Member · 1 Reply
  • 1 Reply
  • Ray Wilcox
    14 February 2011 at 13:48
    Hi Phil, the font information is held in the file CDLfont.mdb, this is in the Signlab/fonts folder. If it is not holding the font info correctly, you could try running the install fonts routine again, or, attached is an unused cdlfont.mdb file (hoping this works 🙂 )move or rename your current file and then copy in the attached after you have unzipped. Then you will need to run the install fonts routine, make sure all boxes are checked.
    Failing that make sure the path= in fontmgr.ini points to the location of the cdlfont.mdb
