Home › Forums › Software Discussions › Signlab Software › signlab not cutting A in text
Posted by Derek Heron on 16 June 2010 at 08:50hi has anybody had this in signlab
its happening all the time now i am running latest version
and when cutting text either the whole cap A or the internal triangle is not putting a cut on it
thought i would ask here before ringing cadlinkderek
Derek Heron replied 15 years, 4 months ago 5 Members · 6 Replies -
Hi Derek
Is it on all fonts?
I had the same a few years ago but only on True type fonts. If you convert the text to curves (break it apart) it should cut. Definitely call cadlink tho.
Matt
cadlink are on the case as always quick and eager to help
will let you know the outcome
derek
What make of cutter is it? Good chance its a plain HPGL cutter.
In a case like this, the first thing i do is change my port location in Signlab to File.
I then plot the job to File and give it a .PLT extension.I then import the cut data back into Signlab via File/Import/ HPGL.
Is all the cut data there? If so, could be a Pressure issue with the knife. -
I’ve had similar problems in the past with truetype fonts, cured by converting to curves.
I think it still does it so maybe a long term problem or my cutter, Summa D60.Steve
I’d do the same as Frank to see if everything is being sent. This method is also a good way if you use Signlab’s Photocut and want to get rid of the photo you have vectorised/traced.
Alan D -
hi just an update
cadlink have been looking into this for me they have tried to replicate the problem and looked at files i have sent them i am going to do a full re install from new discs supplied as they cannot find the problem.
will let you know if its running okDerek
