Home Forums Software Discussions Signlab Software Signlab Male tool path. please help
  • Signlab Male tool path. please help
    Posted by J SIGNS on 1 December 2009 at 15:13
    Instead of my male tool path putting nice square corners on the selected object. The tool path is putting rounded corners on my object. How do i change this back. please help!
    Ray Wilcox replied 16 years ago 9 Members · 13 Replies
  • 13 Replies
  • Neil Speirs
    1 December 2009 at 16:32
    Do yourself a favor Buddie and take 5 minutes to introduce yourself to the site properly, then I’m sure some member with the answer will spend 5 minutes to tell you.
    Welcome to the site 🙂
  • J SIGNS
    1 December 2009 at 16:38
    thanks for your help friend! so kind
  • Neil Speirs
    1 December 2009 at 16:40
    your welcome!
  • J SIGNS
    1 December 2009 at 16:52
    Ok, i want to take a moment to introduce myself properly! I am 28 yrs old from spokane, wa usa. i was born into a family of ten. I am a single dad of three wonderful children. I am 235 and 6ft tall. my name is Ronnie Uzeta. now that i have introduced myself properly, can u answer my question?
  • Scott.Evans
    1 December 2009 at 17:03
    There is a section where people can introduce them selves.
    Its called the "Say Hello" section 😀
    Welcome to the boards
  • Fraser Moore
    1 December 2009 at 17:12
    Check your corner styles settings it may be that.
  • Neil Speirs
    1 December 2009 at 17:13
    because I don’t use signlab myself I done a quick search for your answer but with no joy, most members will be travelling home right now but i’m sure you’ll have your answer shortly 🙂
  • Scott.Evans
    1 December 2009 at 17:20
    What do you mean by "male tool path"
    If you select the object > Right Click a node > then click the cross
    This will change it from being rounded node
    1 December 2009 at 17:23
    Scot
    I think we are talking about engrave lab here, correct me if I’m wrong Ronnie
    anyway welcome aboards,
    cant help with your problem.
    but I’m sure someone will have the answer.
  • Andrew Blackett
    1 December 2009 at 19:12
    Its defo an engravelab function – I’d say check what cutter you are choosing when setting the tool path. If you’re choosing one with a wide tip size then the blue simulation line will simulate a rounded corner – choose a smaller tip size and the "rounding" wont be as noticable.
    Andy
  • Lorraine Clinch
    2 December 2009 at 09:34
    Hi Ronnie
    Within Signlab ‘cut’ tab there are options for various tool paths, which I assume are for engraving, but I am afraid I have no idea how to use them!
    Sorry I am unable to help!
    Welcome to the boards, by the way.
    Lorraine
  • Graeme Harrold
    2 December 2009 at 09:43
    With Engravelab, it you want to follow the line, then use "on line" tool option. Inside, outside paths allow for automatic off-set from the drawn line for differing tool profiles and cut depths.
    As this is modular software, Im guessing your signlab has an engravelab module loaded. Best bet is go back to your supplier for support.
  • Ray Wilcox
    2 December 2009 at 16:47
    Hi, When you create your toolpath, there is a check box "Inlay", uncheck this and you should get the sharp corners again. (Cut> Create Toolpath>Male).
