Home › Forums › Software Discussions › Signlab Software › SignLab Dimension
SignLab Dimension
Posted by James Culpin on 15 December 2009 at 17:06When using the object dimensions in SignLab ES2 Euro, does anyone know how to get the dimensions to into a graphic so i can export them to another program for proofing?
Scott.Evans replied 15 years, 11 months ago 4 Members · 5 Replies -
use the measure tool its usually on the side toolbar .
there is an object measure, then save as an ai file, or convert to bmp and export as a jpg,
I dont think es2 did pdf files but i may be wrongPeter
Peter,
Always use the object dimensions button, good little tool. I have done as AI. The measurements them go across as AI but not the lines marking where that dimensions is do not. At the moment i add them back in in illustrator but adds time. This is why i wondered if you can convert them to graphic.
Any other thoughts? 😕 -
Hi James, The dimensions are strange objects and are made so they don’t cut like the other graphics on the page. The easiest option for you would be to download a pdf writer I use Cutepdf, then you can print the file to PDF and import into any other software with the dimensions. make sure you have the options for "Dimensions and Notes" checked in the preferences.
You Could try:
>Select the line and brake path Ctrl+J
>select the line and make path Ctrl+HOr
Select and outline
Na don’t work
trying to figure a way out
I do it by saving as a pdf file but i believe some versions of signlab do not have this option.
