Home Forums Software Discussions Signlab Software SignLab 9.1 can’t move objects or text with mouse
  • SignLab 9.1 can’t move objects or text with mouse
    Posted by sarah currell on 13 August 2019 at 16:08
    Hi, can anyone help with this……I have been using Signlab 9.1 since it’s been out with no problems and all of a sudden I can’t move anything with the mouse, or draw squares, circles etc to move an object or text I can only use the arrow keys which is taking ages! And if I copy something and try to move it it will drop it a long way off where it should be. Sorry if I haven’t been able to describe it well enough. I’d really appreciate any ideas.
    Darren Summers replied 5 years, 12 months ago 5 Members · 5 Replies
    14 August 2019 at 08:11
    First check the obvious – is the mouse faulty? Does it function normally outwith Signlab?
    Or is it possibly something to do with your operating system? Has it updated itself recently?
  • Denise Goodfellow
    14 August 2019 at 15:44
    I think there’s an “object lock” check to see if that’s ticked
  • David Rogers
    14 August 2019 at 18:21
    Might be the ‘selection tool settings’.
    Where you chose what you grab…the edge or the infill and the snap range.
    D
  • Ray Wilcox
    21 August 2019 at 08:18
    It sounds like you have "Snap to Grid" selected and maybe have a large grid size.
    Look at Options >Grid > Snap to grid or CTRL+W.
    You may have hit CTRL+W in error to enable it.
  • Darren Summers
    16 December 2019 at 10:24
    I have had this issue with SignLab 10 whereby I cannot move objects – either with the mouse or with the arrow keys. However, if I group the objects, I can move them no problem. I am also having a similar issue with not being able to order objects to the front, back, up one layer or down one layer. Yet, when I group the objects, I can move them to any layer.
    Snap to is turned off.
    I am pretty sure I have the latest patch installed.
    Whilst I can live with it, it would be better if there was a solution or someone can let me know if I am doing something wrong.
