Home Forums Sign Making Discussions General Sign Topics Sign Post advice needed, Please Help?
  • Sign Post advice needed, Please Help?
    Posted by Brian Little on 28 April 2013 at 13:49
    hello im looking for a metal type post for a sign .customer wants to be able to move it a bout from one grass section to another. Need a spike at one end
    Regards Brian
    Martin Pearson replied 12 years, 8 months ago 3 Members · 5 Replies
    28 April 2013 at 18:32
    What sort of size Brian? Grafityp do a plastic frame with 2 spikes for pushing in to soft ground, think they are about A3 sort of size, there is another sort that is bigger & a metal frame but I can’t remember where I got those ones from at the moment.
  • Ewan Chrystal
    28 April 2013 at 23:25
    depends on what size you need? Could you make one with something like a scaffold pole?
  • Brian Little
    30 April 2013 at 08:20
    hi guys havent been able to get a hold of people but id imagine the top of sign no more than 3ft
  • Brian Little
    30 April 2013 at 08:23
    sorry 3ft off the ground
    30 April 2013 at 09:12
    How big is the actual sign though Brian? The metal frame I mentioned might do will see if there is a supplier name stuck on when I’m up the unit.
    Failing the then you would be looking at modifying a post, can look at doing that when up at the unit as well.
