Home Forums Sign Making Discussions Neon, LED, Lighting Sign mounting for attachment to cone
  • Sign mounting for attachment to cone
    Posted by Richard Urquhart on 11 February 2010 at 15:57
    Hi all been asked to quote for a job for a few signs and the customer wants to put these on cones. I have seen before an angle bracket with a hole in it and this is riveted to the sign blank and then the hole sits over the top of the cone, can any one point me to these brackets please thanks Rich
    Geraint Rhys Williams replied 15 years, 9 months ago 11 Members · 26 Replies
  • 26 Replies
  • John Harding
    11 February 2010 at 17:32
    http://www.manchestersafety.co.uk/index … lAodUV-KXQ
    any good (?)
  • Richard Urquhart
    11 February 2010 at 17:35
    Its good but its not right!
    just need the brackets not the signs?
  • John Harding
    another
    http://www.health-safety-signs.uk.com/R … igns.shtml
    ok looking for brackets
  • Richard Urquhart
    17 February 2010 at 18:13
    Getting know where fast on this and really need your help, trying to find the correct mounting system for cone type signs I need to make some and cant source the sleeve or the straps these type of signs use, please please help me xxx
  • David Lowery
    17 February 2010 at 18:50
    Try ASD Metal Services. They do a range of clamps for different sizes of posts so maybe a 150mm clamp for the lower part of the cone and a 76mm clamp for the upper part????
    Worth asking them 😕
    17 February 2010 at 18:57
    or maybe Blackburns 01234 684 100, may be a wild goose chase but have always found them helpful.
  • John Hughes
    17 February 2010 at 19:20
    Hi Richard – i’ve posted a pic in other section because i couldn’t upload it here.
    Hope it helps
    17 February 2010 at 21:32
    Rich, at the prices shown above, I would just buy them in. hardly worth the effort to buy the brackets, and make the signs!
  • Richard Urquhart
    17 February 2010 at 21:40
    There to a spec that I need to make not standard type signs, so would like to make the sign and the attach a bracket to the rear, there must be a supplier of the mount used, just need to find them. A prize for the first person to find a supplier of just the bracket !!!!!!!!!!
    Peter I may be able to buy them in from them at the size I need and apply a digital print to the face of theres???
    ps thanks to Lynn today for simple signlab help Rich
  • Harry Cleary
    17 February 2010 at 21:53
  • Richard Urquhart
    17 February 2010 at 22:09
    Harry thats where I got the picture from, just need to see if they just supply the mounting. Will let you know on prize.
    17 February 2010 at 23:05
    might as well just use heavy duty zip ties!!
    what stops the sign slipping around in the wind?
  • Kevin Flowers
    18 February 2010 at 00:00
    Rich
    why not use a 4” & 2” pipe wall clips from local plumbers merchants
  • Vic Adair
    19 February 2010 at 12:40
    To me it looks like a couple of rubber straps that are riveted on and stretched across the cone 😕
  • Richard Urquhart
    19 February 2010 at 19:34
    Thanks for all your help on this I have been so busy and not had time to follow up. Tim I think your onto something there and sounds the best way , doing this there is nothing that can snap off as the rubber will give.
    OK next question where could I now get rubber bands that are thick and wide like this???????????????
  • David Lowery
    19 February 2010 at 19:37
    The big rubber band shop :lol1:
    What about inner tubes 😕
  • Richard Urquhart
    19 February 2010 at 19:43
    Inner tube good idea but would need to be thicker like 3mm thick and 8mm wide and fit around 100mm and 250mm. I just want to be able to buy them in, Calling all rubber band suppliers 😮 😮 😮 😮 😮 😮
  • David Lowery
    19 February 2010 at 19:46
    Didn’t Titanic have some stock…i’m sure they had a band on ship ….i’ll get me coat 😳
  • Richard Urquhart
    19 February 2010 at 19:48
    like the bands that people put on there wrists but bigger
  • David Lowery
    19 February 2010 at 19:50
    Just had a thought (yes..it hurt) try a rubber stamp manufacturer.
    They should be able to cure some natural rubber to the dimensions you asked for. I kmow this because I used to be employed by NatWest and used to make all their rubber stamps. The rubber is cured on a vulcaniser so rails could be used leave space for the finished article.
  • David Lowery
    19 February 2010 at 19:52
    Garden centres!!!! they have rubber straps for fixing trees to posts!
    EDIT
    http://www.essentialscompany.co.uk/Ties.html
  • Richard Urquhart
    19 February 2010 at 19:57
    I may have the plan !!!!!!!!!!!!!!!!!!
    http://www.nene-rubber.co.uk/rubber-strip.php
  • Richard Urquhart
    19 February 2010 at 20:11
    Dave your a great help, just found this
    soft strapping a few down the page
    rivet this through the sign with support at the rear and to the approx size of the top and middle of the cone, think that could be job done !!!
    http://www.tynemoulds.co.uk/Products/tree01.htm
  • David Lowery
    20 February 2010 at 07:17
    That’s the ones I was thinking of 😀
  • David Lowery
    20 February 2010 at 07:19
    OOoops….double post 😀
  • Geraint Rhys Williams
    20 February 2010 at 09:32
    What about the Rap Straps that were on Dragons Den?? Anyone remember them??
    http://www.rapstrap.com
