Home Forums Sign Making Discussions Industry News (Archive) Sign Maker designs & markets his own patented vinyl rack
  • Sign Maker designs & markets his own patented vinyl rack
    Posted by .News on 20 November 2005 at 23:48
    Jon says:
    Having reached a point where I needed to organise my own workshop, I searched endlessly for ready made vinyl racks but found it a fruitless task. So I decided to design my own." "there must be other signmakers in the same situation", I thought. I was fed up searching for rolls , or picking them up off the floor only to find damaged ends, or just searching through boxes that the rolls came in. All this takes time, and time is money at the end of the day. Once i decided on the design and style/size of the rack we set about making some prototypes. I wanted to make a racks that can be moved around easily, so decided to make it free standing, that way your’e not fixed just to using them in one place.
    To start with i decided to market 610mm wide rolls racks, due to the fact most smaller signmakers that either work from home or smaller studio would have a smaller plotter so it was a good starting point, & naturally I registered my product with the patent office. What is probably unique about the racks is that there are NO screws; in fact there are only FOUR component parts, which makes it very easy to assemble ( within minutes) and as such, it comes flat packed. A very simple yet effective design allows each roll to be front loaded for ease of use and visibility. Just need to insert a piece of hardwood dowel (not supplied) through the roll onto the pegs and the task is then complete.
    It’s that simple and is a vital edition to any sign studio. Having an efficient workshop saves time and money protecting the investment you made in your vinyl. No more damaged roll ends, no more endless boxes to sort through to try and locate the right vinyl.
    Whether you stock 5, 10, 20 or even 50 metre rolls, it’s not a problem. Our racks are able to hold 8 x 50 metre rolls at 610mm wide, but why stop at vinyl? Our racks will hold banner rolls, application logs,bubble wrap etc. The overall product dimensions are 1525mm high x 762mm wide x 900mm depth and weighs approximately 12 kgs.
    For further information
    Jon Fields
    0114 239 0441
    Jamie Kimp replied 17 years, 12 months ago 8 Members · 9 Replies
  • 9 Replies
    21 November 2005 at 00:10
    well done john…. πŸ˜€
    i know it couldnt have been easy getting it going….but i wish you all the best πŸ˜€
  • Jon Fields
    21 November 2005 at 19:10
    Thank You Nik..
    I really appreciate it.
    Jon
    πŸ˜€
    21 November 2005 at 19:16
    Good luck Jon,
    Simple and effective design,
    Do you do a double sided version?
  • Jayne Marsh
    21 November 2005 at 20:02
    Peter I was going to ask the exact same thing! πŸ˜€
    21 November 2005 at 22:10
    same here… well done jon. πŸ˜› wish you all the best with the racks mate… πŸ˜€
  • Carrie Brown
    21 November 2005 at 23:11
    Well done Jon, good luck with it πŸ˜€
  • Jon Fields
    22 November 2005 at 18:51
    Peter/jayne..thanks for asking, we can make,double sided if required, what you will find, is the legs are longer so the rack will feel like its not against the wall etc, so i guess you will need more space, but if that’s not a problem, then yes we could. I had designed them in mind to have against a wall as an example to save space etc..although I have mine in different places, that’s the beauty of freestanding racks.We have made 1220 wide in the same design..the stock items are 610mm wide.. I have suggested to other customers that already have bought the racks that they could “daisy chain” 2 racks to make 3, depending on what they are holding…hope that helps
    Rob/Carrie thanks for your support as well.
    Jon
  • FrancisGeraghty
    6 November 2007 at 12:33
    Great simple idea !
    Do you have a price list ?
    How much to deliver to Ireland?
    Francis
  • Jamie Kimp
    3 January 2008 at 10:58
    That’s funny you mentioned this. I am in the process of making my own. I have a cheap vinyl cutter. It’s the one where you have to put a bar through the vinyl tube to hold it in place. So I have made the same sized round bar to rack my vinyl on. I am sure it will save loads of time in the long run.
    Cheers for this
