Sign Board Help
Hello!
Can anyone please advise me on the most suitable (and cheapest) board to use for some signs. They are quite large (about 3m x 1½m), to be fixed flat onto either walls or wood. Need to last about a year . Currently the signs there are unframed and appear to be just 5mm foamex, some are glossy (is it called forrex top?), some matt. They seem to do the job okay, but some appear to be slightly warped – (you can only see this when you get up close). I don’t know if they are slightly warped due to the fitting, or due to it being foamex. I have been told that you can get an “outdoor grade” foamex, does anyone here use it?I don’t often get asked to do signs this large – usually just internals or short term builders boards for which I use foamex.
Any advice would be much appreciated.Many thanks
Ali
