Home Forums Sign Making Discussions Neon, LED, Lighting sign base for vertical dibond panel
  • sign base for vertical dibond panel
    Posted by Paul Munford on 3 June 2013 at 13:00
    Hi All,
    Can anyone suggest a supplier of a slot in/bolt on sign base that will hold a sheet of 3mm dibond up vertically?
    Sheet size will be 1000mm wide x 2000mm tall
    Paul
    Paul Munford replied 12 years, 6 months ago 2 Members · 2 Replies
    3 June 2013 at 13:24
    Robert Horne do them…
    the one i have from them is about a metre wide.
    the thing is, over the 2 metre depth, i recon you may see it "leaning" as 3mm isnt very rigid over a certain length.
  • Paul Munford
    3 June 2013 at 15:08
    Thanks Rob, will give RH a shout. Looked everywhere for something like this 🙂
