Home › Forums › Sign Making Discussions › General Sign Topics › shop name sign material
Posted by Alan Jenkin on 9 November 2008 at 17:45What material do you use for putting up over a shop window (on the wooden space above) to put the shop name on??
Peter Normington replied 17 years, 1 month ago 5 Members · 6 Replies -
Theres loads of options. I prefer using a Dibond or Alu Composite Pan, but lots of people go for a panatrim type sign where the sign slides into the frame after mounting.
quickest and easiest for me is panatrim signs with composite board panels.
can also use shallow sign trays……see Ashby for samples
I would simply paint the fascia and put up flat cut letters on locators.
What I wouldn’t do is paint it and apply vinyl unless the paint job is absolutely first class……… 😮
It depends on the fascia that is there to start with, and what the customer wants,
vinyl to a complete new sign, flat cut or moulded letters, illuminated from the front or back, really need a bit more info to advise the best route to go.Peter
