Home Forums Sign Making Discussions Buy – Sell – Employment Sheet Media Vertical cutters
  • Sheet Media Vertical cutters
    Posted by Mark Newman on 12 March 2017 at 11:46
    hi im looking for a sign board cutter, no rush for it.
    not sure why the prices of some are up in the £2000 range? it cant be that hard to manufacture surely.
    looking for something a lot more reasonably priced, may have to find a used one if need be can anyone help?
    Mark Newman replied 8 years, 10 months ago 2 Members · 2 Replies
    12 March 2017 at 17:54
    Will depend on what you are wanting to cut, the other thing you will need to consider is where you locate it, I have one but it produces a lot of dust, has a hoover type attachment but that isn’t great so I need to make sure it is located well away from anywhere I am doing vinyl work.
    If your looking to cut mainly foam & ACM then one of the blade type cutters that don’t produce dust may be a better option.
    If you need something that will cut large boards then going to cheaply will mean you end up with a machine that isn’t very rigid which will affect the accuracy you can cut with.
    Try a search on the forum as the question has been asked a few times & the answers you are looking for may already be here 😆
  • Mark Newman
    15 March 2017 at 03:35
    Yeah it’s the blade cutters I was looking at. They range from £1600 to £2000 though. Seems crazy for what it is…
