Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters sharing a CE5000/60 between 2 PCs
  • sharing a CE5000/60 between 2 PCs
    Posted by Nick Eccles on 20 July 2013 at 10:33
    I’d like to use the cutter from 2 different PCs, I’ve spoken to Graphtec and there is no way to share the USB device using windows sharing.
    Does anyone / has anyone tried using an external USB device sharing switch with their Cutter ?
    Any problems etc ? Thought I would ask before buying one to try !
    Nick.
    Warren Beard replied 12 years, 5 months ago 4 Members · 6 Replies
    20 July 2013 at 11:30
    quote :
    i drive 3 graphtecs (2 usb 1 lpt) from any one of 3 pc all at the same time if you so desire
    done by using the graphtec windows driver from corel and windows printer sharing over the network.
    how you would do it from say eg flexy i have not a clue
  • Nick Eccles
    20 July 2013 at 11:38
    Thanks Chris, Do you use Cutting master ?
    I don’t use flexi (at all) I cut direct from Corel Draw or AI using Cutting Master …
    I’ve tried sharing the cutter from the PC it’s attached to but Cutting Master on the other PC will not recognise it as a cutter ? within Windows what Port type do you set it up as/share?
    If you have any screen shots you could share (or PM / email) it would be great !!
    Thanks in advance
    20 July 2013 at 11:48
    cutting master has one use thats to clutter up my disk untill the odd blue moon i want to use it.
    give me a ring as its to long winded to type it all out and you will be cutting direct out of corel
  • Nick Eccles
    20 July 2013 at 15:44
    Thanks Chris….
    Ahhh I forgot I could do it like that, will try it out and may call you if I can’t get it working. Thanks for the help
  • Jayson Godridge
    25 July 2013 at 19:40
    Incase you haven’t solved this yet, i bought a simple usb switch device in the early
    days when i had a similar setup. It is literally a block with a push button on it. It connects to both pcs via usb cables and then to your plotter (or any other usb device)
    You can then just push the button and switch between which machine sends the data ( drivers had to be installed on both machines)
    I think it was called a usb device switch or something….i may even still have it kicking about somewhere, will look and try to post a pic
  • Warren Beard
    25 July 2013 at 20:42
    yes I use the switching device as I share 2 cutters with 3 imacs, i got a 4 way switch so can connect up to computers to it, simply push your machines associated number on the device for the cutter you want to use and you’re connected.
    Only down side is distance of cable, I had to move slightly closer as the cables I used were too long and wasn’t "powerful" enough to carry through so had to shorted the cable but it’s still about 7 or 8 meters away.
