Home Forums Vinyl Cutter Discussions Roland Cutters Setting up pnc 1860 with my laptop.
  • Setting up pnc 1860 with my laptop.
    Posted by James Beavon on 8 February 2011 at 17:48
    Hi.
    ive recently bought a laptop, to connect up to my plotter pnc 1860.
    i currently use it on an ancient pc tower running win 98 out of its serial port.
    So now im using a usb ( at the computer end ) as there are no serial ports on laptops or new pc.
    ive bought a USB to serial cable which connects the two devices, and installed the driver for the cable.
    In the device manager the cable properties says its on COMM 3 so i set my software ( signgo ) to use COMM 3.
    aaaannnndddd……it doesnt work. does anyone know what im doing wrong or what im missing here.
    James Beavon replied 14 years, 10 months ago 3 Members · 9 Replies
  • 9 Replies
  • James Beavon
    8 February 2011 at 18:31
    just thought i would add im using windows 7.
    ive tried loading the driver for the pnc 1860 ( off their website ) but it says its not compattable with this version of windows.
    however in signgo it has the option to select my plotter so i imagine the driver is included with signgo. ive never had to install drivers before, using my pc ( win 98 )
    ive a feeling i cannot use my cutter with windows 7 at all.
  • David-Foster-
    8 February 2011 at 19:52
    It is probably the USB to serial cable. The best ones are Keyspan adapters. I have one that works but I prefer using my old XP desktop for plotting, just seems rock solid. You can run Windows XP virtually on Windows 7.
    8 February 2011 at 21:04
    James, it may well be a driver issue it is difficult to say. What sort of serial to USB adapter did you buy?? There are basically 2 types with different chip sets used in their production. Most of the better quality adapters use a FTDI chipset and this is the one that you want. I would imagine the ones David has mentioned have this chipset but don’t know for sure.
  • James Beavon
    9 February 2011 at 14:49
    well to be honest i bought a cheapo one from off ebay for £3.
    i thought a cable is a length of wires, obviously not eh.
    will try the keyspan FTDI cable.
    9 February 2011 at 15:53
    James, it’s a bit more than a bit of electrical string with a different bit on each end :lol1: :lol1:
    From what I have read and been told the FTDI chipset is much better for stuff like plotters, Graphtec tech support told me that was the one I needed.
  • David-Foster-
    9 February 2011 at 16:00
    It is not just a cable, it is an adapter with chips inside 😉
    If you get the keyspan or similar as Martin says, you will still need a serial to serial cable as well.
    9 February 2011 at 18:26
    Not strictly true David, you should be able to get a USB to serial adapter with a male or female connection.
  • David-Foster-
    9 February 2011 at 19:20
    Sorry Martin, I was just referring to the keyspan that I have. It just uses the serial cable that comes with the plotter that would have connected to the serial port of a PC.
  • James Beavon
    16 February 2011 at 18:34
    OK.
    just bought a keyspan from amazon.
    computers harddrive died today as well and i had to use my old / old computer. good job i keep my old computers.
    really need to switch to laptop.
    ill update this thread with result when it gets delivered.
