Home Forums Software Discussions Corel Software Setting a colour to CutContour in X3
  • Setting a colour to CutContour in X3
    Posted by Gary Birch on 21 October 2009 at 16:22
    Hi all
    I have been trying to set a colour in my pallette to CutContour and while I can rename the colour, when I export as a eps instead of getting the marching ants in Versaworks i just get a solid line of my chosen colour. What am I doing wrong?
    A step by step guide would be a great help if anyone has the time.
    Thanks in advance
    Gary
    Gary Birch replied 16 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Karl Williams
    21 October 2009 at 16:38
    I don’t use your rip mate. But what I do in the Onyx rip is enable the software to cutcontour. The path you send with your image has to be a light green. When CutContour’s enabled in the rip it recognises the green path as a not printable image, so sends this to the Cut server ready for decal cutting.
    Hope this makes sense?
  • Carl Maguire
    21 October 2009 at 16:55
    quote Gary Birch:
    Hi all
    Thanks in advance
    Gary
    Have you made sure that the line width is a Hairline as well as CutContour we use X3 all the time and Versaworks so if that doesnt work ill try to give you a more detailed option if neccessary
    21 October 2009 at 17:01
    gary i don’y know VW but its the colour name that has to be correct not the colour.
    in rolands colourrip you make a new colour from the chart in corel then give it the cutpath name (CutContour) i think for VW
  • Gary Birch
    21 October 2009 at 19:16
    Thanks for you help guys. I have done this before and cannot for the life of me remember just how.
    I have made sure I have named the colour CutContour as previously done and in fact the same as I have it on the pc which is set up to create cut contours for Versaworks. I am thinking outloud here but can I save that palette and then open it on the other pcs?
    I am pretty sure that I have seen detailed instructions on here before but after numerous searches cannot for the life of me find it.
    Thanks for the help so far with this.
    Gary
  • Craig Newton
    21 October 2009 at 21:30
    same as chris i run colorip and colour has to be called ‘cutpath’ but also make sure in vw in print setup you have the ‘process cut path’ box checked, good luck, craig
  • Carl Maguire
    21 October 2009 at 23:06
    quote Gary Birch:
    Hi all
    Thanks in advance
    Gary
    Try thisfor a step by step Guide –
    http://www.rolanddg.co.za/bobnotes/HowT … ontour.pdf
  • Gary Birch
    22 October 2009 at 08:04
    Cheers Carl its sorted!!
    I already had one pc which was set up to create them but just wanted to have the ability to do so with the rest.
    Thanks again
    Gary
