Home Forums Printing Discussions Uniform Printers service call 0104
  • service call 0104
    Posted by John Hughes on 9 June 2010 at 08:49
    Running a Grenadier and just coming up with ‘SERVICE CALL 0104’
    Does anyone know the cause of this please?
    I’ve done a Roland & Google search but no joy.
    john
    Kevin Flowers replied 15 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
    9 June 2010 at 09:01
    to do with the cap sensor.
    could be out of sequence so do a complete cold start up. but make sure that there is nothing fell off or obstructing the capping stations movement
  • John Hughes
    9 June 2010 at 09:15
    Cheers Chris – tried that but no joy.
    PRINTERS !! Like women – pain in the @@@ sometimes but can’t do without them 🙂
  • Kevin Flowers
    9 June 2010 at 10:06
    normally capping station as been wound back up to tight after manual clean or dried ink on the wind up mechanism. Try winding up & down a few times manually then do a restart
  • John Hughes
    9 June 2010 at 11:17
    Hi Kevin – got the opposite, capping station down at the bottom. Been told need a new pulley / belt but 10 day lead time !!!
    Starting to panic about that kind of down time.
    9 June 2010 at 11:27
    have they suggested away to seal the heads in the meantime.
  • John Hughes
    9 June 2010 at 11:33
    I can wind up the capping station up by hand to seal but told the supplier to go and try and find a pulley from somewhere else – surely it doesn’t 10 days even if it’s gota come from Japan.
    Also been phoning around re a new printer – Soljet 111
  • Kevin Flowers
    9 June 2010 at 12:50
    what area are you in? Have you confirmed that the pulley belt is knackered could it be as simple as a grub screw etc come loose. If you can get it off try your local bearing & drive belt stockists you would be surprised what is kept on the shelf some times they just have to machine to match drive shaft etc
