Home › Forums › Software Discussions › General Software Topics › SBD FILES
SBD FILES
Posted by Adam Ross on 12 December 2007 at 20:33Hi i am currently using Signblazer, could anyone tell me if there is a way to convert an SBD file into a jpeg, bmp or similar.
Adam
Phil Jones replied 17 years, 10 months ago 5 Members · 5 Replies -
Adam I dont know the software, but it may have an export command.
but if it doesn’t you could use something like corel capture, or even a screen print to paste and then crop the image in a raster program.Why do you need to convert? depends on how you should do it.
it does have an export function but it will only export Tif,jpeg,dxf or eps only if these were origionally that format, and design work i do for the cutter is automatically saved as an sbd file with no way that i can see of changing it. i need them is a format such as a jpeg to export to another program so that i can send designs to customers via e-mail, if i send them as a sbd file they cant open it
Assuming you can print from Signblazer, download one of the many FREE pdf creators ie Primo/Cute pdf and print to the installed driver which will produce a pdf. Most people have Acrobat Reader, that is the way I send customer’ proofs.
Alan D -
I usually put the whole design on the clipboard and paste it into Corel Photoshop. Then adjust the size etc. for e-mail or printing & save as JPeg.
Maybe not the right way to do it, but it works for me -
if you export as jpeg you can send it from where ever you exported it to, i do this all the time from signblazer.
Phil
