Home Forums Printing Discussions Sublimation Printing sawgrass profiles for corel & ricoh
  • sawgrass profiles for corel & ricoh
    Posted by Hugh Potter on 30 May 2013 at 17:28
    Hi all,
    just a quicky,
    I’m running corel X5, do I need to use the ‘Powerdriver R’ icc colour profiles??
    if not, which do I require please?? I’m just setting the printer up for the first time,
    thanks,
    Hugh
    Hugh Potter replied 12 years, 6 months ago 3 Members · 6 Replies
  • Lee Reeves
    30 May 2013 at 19:02
    What type of sawgrass inks are you using if its the subli R then you need the power driver R icc profiles you can download them from xpres
    Hope this helps
    30 May 2013 at 19:59
    sublijet R, yes, it said something about ‘unless you are not using corel draw or photoshop cs..’ then you do not need o download the icc profiles,
    i was a bit confused to be honest!
  • Lee Reeves
    30 May 2013 at 20:23
    It’s been a while since I’ve used coral but when we did we used the powerdriver R profiles. We are converted to mac and illustrator and don’t like it when I have to use coral draw now not that it’s often.
    30 May 2013 at 20:27
    ok Lee, thank you, I’ll install it tomorrow
    H
  • John Gregson
    5 June 2013 at 10:52
    Hi Hugh,
    If using a ricoh printer you would use the Powerdriver software – no need for icc profiles, unless you’re using a mac.
    Full instructions should have came with printer or are available on sawgrass website.
    Cheers John
    5 June 2013 at 13:30
    cheers John, I’ve figured that out now, all I have to do is print something now I guess!
