Home Forums Sign Making Discussions Vinyl Sand Blasting using regular 7yr Vinyl?
  • Sand Blasting using regular 7yr Vinyl?
    Posted by Kevin Fryer on 11 December 2007 at 10:11
    Hi can any one help will 7 yr vinyl stand up to sand blasting thanks
    MOD-EDIT
    Topic Title Edit
    Please use descriptive topic headers when posting.
    Kevin Fryer replied 17 years, 11 months ago 5 Members · 6 Replies
  • Ian Bingham
    11 December 2007 at 12:02
    no!
  • Steve Underhill
    11 December 2007 at 12:13
    Only if you leave it on for an extra 7 years.
    then nothing including nuclear weapons will get the stuff off.
    Otherwise no,
    however sandblast film does funnily enough. :lol1:
  • Dave Bruce
    11 December 2007 at 12:46
    That depends if you are pressure blasting or suction blasting. Blasting in a cabinet with a suction gun say on to glass you would get away with it, I have, but if you are pressure blasting say to do a wood sign, you need blasting vinyl, as Steve says.
  • Kevin Fryer
    11 December 2007 at 15:21
    cheers it for blasting on to marble fire places
  • Steve Morgan
    11 December 2007 at 15:22
    As Dave says, it depends what pressure you are working at. I regularly blast glass using 7 year material and also 10 year cast. Most of the time I use glass bead as media but i do, on occasions, use a sand type media without problem, but I rarely go above 50psi.
    I have successfully worked onto slate with sand without loosing the mask and that was closer to 100psi.
    Simple answer is try it.
  • Kevin Fryer
    11 December 2007 at 15:25
    THANKS STEVE
