Home Forums Vinyl Cutter Discussions General Cutter topics Running a cutter from a generator?
  • Running a cutter from a generator?
    Posted by Joe McNamara on 1 June 2009 at 08:13
    Hi All,
    Anyone know if I can run a cutter and laptop from a regular petrol genni, or do I need some special type?
    Anyone ever done this as a mobile setup?
    Joe
    John Harding replied 16 years, 7 months ago 7 Members · 8 Replies
  • 8 Replies
  • Harry Cleary
    1 June 2009 at 08:22
    have a peep here Joe
    http://www.uksignboards.com/viewtopic.p … ors#202873
    1 June 2009 at 12:18
    Would using a small UPS smooth the power? My UPS cost less than £30 and saves power outs and I believe smooths the power too but I’m open to correction.
    Alan D
  • Stephen Morriss
    1 June 2009 at 13:08
    I was going to suggest the same Alan.
    I’ve used a ups and a geni to good effect a few times.
    The power failed here while printing so I fired up the geni and plugged the ups’s into it, all my computers and the Cadet run through ups’s (big one for the printer) and it’s saved a few prints from power brown outs.
    Also try inverters running off a 12 volt battery being charged by the vehicle.
    1 June 2009 at 13:11
    well this is on my mind, but i need to know what our power wattage is on the cutter to see what kinda of load it will have on the generator/UPS
    oh i found in the past, the UPS’s can also be a pain!… some will shut off after 5 minutes regardless if the battery is tired or not.
  • Ian Muir
    1 June 2009 at 13:53
    Cutters don’t take much power, a few hundred watts only, big printers take lots more, up to 2000 wattsfor general sign application ones.
    If only a cutter then as said a geni + ups or leisure batteries and an invertor…. go for more expensive invertors that convert DC to sine wave as opposed to dc to square wave (which is fine for running drills and stuff but not so good for electronics….
    Ian :lol1:
  • Stephen Morriss
    1 June 2009 at 14:51
    I use a 1400va UPS to run the printer and Summa D60 cutter at the same time, it has overcurrent protection and has never given any sign of struggling, even running the printer with heaters on for a few minutes while I sorted the geni.
    Most quality ups’s are modified square wave to make them suitable for computers etc and as pointed out if you go with an inverter you really need one with the modified square wave.
    It’s rated at 10A/980w max.
    1 June 2009 at 15:02
    not a gennie, but i have successfully run my summa and a laptop (and lighitng in evening) from a 3kw power invertor. a simple re-charge of the vehicle battery for 15 mins every couple of hours was enough to keep us at it all weekend.
    Hugh
  • John Harding
    1 June 2009 at 22:45
    Hugh – have you got a link for where you got your invertor from please dude
