Home Forums Printing Discussions Roland Printers Ruddy PC 60 Again – not printing?
  • Ruddy PC 60 Again – not printing?
    Posted by storeinet on 7 April 2005 at 19:17
    Here we go again………
    I’m trying to print with the PC 60, but having no luck what so ever, it’s been a while since I last used it, so any help/recommendation greatly appreciated.
    I just can’t get the thing to print not even one line.
    I’m using Signlab 6.1 R 13.
    All I get is the busy lights flashing along with the colour light.
    I can cut with no problems, but I just can’t seem to get it to print. I have uninstalled Signlab and the printer drivers and re-installed, but with no effect.
    I’ve tried spot colours and process but to no avail. Played around with the bar codes. The vinyl is covering the sensors. The friction feed rollers are in line with the grit rollers.
    The printer looks for the colour then the lights just flash.
    I’ve tried to print the simplest of thing, text “graphics” in process and spot (various colours) all with no joy.
    Please please help.
    Bill Dewison replied 20 years, 7 months ago 10 Members · 12 Replies
  • 12 Replies
  • Richard Urquhart
    7 April 2005 at 19:29
    i know this may seem like a silly thing but i will say it don’t all laugh but are carts facing right way ,only cause i have made this mistake when i first started using a PC60 ??? 😳
  • storeinet
    7 April 2005 at 19:31
    Thanks for the input, yep the carts are the rightway round.
    Dan
    7 April 2005 at 19:34
    i was goning to say that (from memory) that sounds like a colour has run out and needs changed. 😕 but having read the rest of your post, maybe not 🙄
    do you have tape covering “both” sensors?
    is your page size correct?
    i am guessing now… so ill shut up 😉
    7 April 2005 at 19:52
    does the print head move at all?
  • Brian Hays
    7 April 2005 at 20:20
    What driver are you using? Signlab driver or the Roland driver?
  • Mike Grant
    7 April 2005 at 21:10
    Have you assigned the correct colours in your program for the carts?
  • storeinet
    8 April 2005 at 09:12
    thanks all.
    Rob – I don’t have tap over the sensors but this should not be a problem as i can cut with no probs. As for page size again can’t see this being an issue as i’m at this point just trying to get it to print basic tex 100mm long and sheet size is A4 at the mo.
    Nik- Yes the print head is moving, just not finding any of the carts, and i mean any.
    Brian- I’m not using Colour Master, so it’s the roland driver. The PC60 driver is selected in Signlab but this does not show when going to print, so loaded the Roland driver.
    Mike- yep assigning the right colours from the PC60 palette.
    Thanks all.
    Dan
  • Martin Armitage
    8 April 2005 at 09:23
    I know when we used to have a pc60 if you wanted to print – on sending to the printer you would have to tick a box. 3 options i think cut, print, and print and cut. Basic i know but if you havn’t used it for a while!
    8 April 2005 at 10:16
    hi
    if busy light flashing – it has data to prosess
    if the colour light is flashing it does not have the colour its told to use loaded
    do a small test using black only spot colour setting
  • storeinet
    8 April 2005 at 10:24
    Hi Chris
    Done that with spot black – gold – silver etc no joy.
    Dan
  • Gordon Forbes
    8 April 2005 at 23:19
    If the gold, silver etc is non Roland check that the bar code (black and chrome barcode the machine reads) on the cart is the right code for the colour. I got caught out like that from another supplier had to put an orange ribbon in a silver cart to print orange once.
    If they are wrong tell them to send you proper ones.
    Worth a check anyway.
    hope it helps
    goop.
  • Bill Dewison
    9 April 2005 at 12:00
    If you have a copy of CorelDRAW you can run a quick test to make sure it isn’t a software issue. Make 3 boxes, one yellow, one magenta, one cyan.. then select the PC60 as your printer. Bit of alignment needed on the page, but it’ll tell you whether its a problem with the printer or with the software.
    Cheers, Dewi
