Home › Forums › Sign Making Discussions › General Sign Topics › Router bit help needed please
Posted by Rich Cooper on 15 April 2016 at 19:24Hi everyone,
Im hoping someone on here can point me in the right direction for a 90 degree router bit with a 3mm flat bottom for routing tray signs, ive searched the usual online places but cant seam to find one anywhere.
Any help is appretiated thanks Rich
Duncan Wilkie replied 9 years, 8 months ago 6 Members · 7 Replies -
ITC http://www.itc-ltd.co.uk/products/ sell them page 45 in the Folio catalogue Listed as Dibond toolhttps://issuu.com/itcltd/docs/folio_cat … 6_web_lr/1
I took a normal 90 degree bit and ground off the bottom couple of mm on a grinder. Needs must, couldnt find the proper one in NZ! Works a treat.
You have to use the "spiral down" approach when cutting so it doesn’t overheat when starting the cut..Simon.
Complete CNC Solution will be able to assist you with this
It’s not just the tool your buying remember you need to know the correct settings to run this at…guys at CCS can advice on all settings needed according to the machine your running.
Will save you a lot of messing around!
Brilliant thanks everyone for the help, ill get one ordered this afternoon.
http://www.trenddirectuk.com/alu-01×1-4tc.html
i bought one from here last month, and my first ever sign tray i made is proudly on the local main street 🙂
It seems the tips of V carving bits have a tendency to break of, so we just use one in that condition to slot the ACP. It works well for us. Nice tight bends.
Just a heads up there are different grades of these ACP sheets. The Econo grade has a thinner metal face and it is suitable only for flat applications I will usually crack when bent. Use the panels with the thicker "skin". Ex. E-Panel is thin, Dibond is thicker – same manufacturer.
