Home › Forums › Sign Making Discussions › Neon, LED, Lighting › Router bit for producing dibond trays?
Posted by Andrew Blackett on 25 September 2009 at 08:32Morning All,
Can anyone point me in the direction of the correct bit for producing the dibond trays.
I believe its a 90 degree one, but I cant find any with this illusive flat bottom!
AndyAndrew Blackett replied 16 years, 2 months ago 5 Members · 13 Replies -
I have made hundreds but never used the correct bit just a normal half round bit works just fine.
Rich -
Just rang Jag and one bit on its own is £49, thought that was a bit dear – am I wrong??
Andy
Rich, how does that work???? I’ve googled a half round bit but can only come up with ones that profile the edge of the board.
I assumed that I would need to cut the groove to a point to make it easy to fold.
Andy
Just the grind the point of the bottom and try that, should be fine.
Andy, I’ve always used an ordinary "V" groove bit for the ones that I have done. Never had any problems the same as Rich. Not sure how much difference the flat bottomed bits would make but they are a lot more expensive than the normal "V" bits. Have seen them cheaper than £49 but not that much to be honest so never bothered buying one.
Just try a standard half round 15mm bit, set depth to just leave a thin layer on top of 2nd ali sheet and it bends really easy with no cracking to the face.
If you go to deep and don’t leave enough plastic the sheet will crack, if you don’t go deep enough the sheets hard to bend !
really easy once you have a play at cutting depths -
I use a pointy one (90deg I think) with the point ground off. You need to grind quite a bit off the point, until you have about a 3.5mm flat surface. Price depends on what quality of bit you buy. A straight bit works OK though, I’ve used a 6mm before.
Rich,
Just tried it with a 12mm half radius job…………………… my man you are a genius!!
Just got to play about to see how best to get the corners looking neat and tidy… suggestions gentlemen??
Andy
Cant PM mate but if you PM me with your email I’ll send you something by return
Andy -
Also whats the best way of fixing these?? the least visible way anyway.
Sorry for all the questions but I’ve finally found a use for the router I bought 2 years ago to build a bathroom cabinet (which we bought off ebay about a week after I got the router as it was easier!)
Andy
Andy, I normally just make up a frame with right angled ally that the tray just fits over. Fit the frame to the facia and then slide the tray over the top and fix in place with rivets.
Cool, will have a proper play next week and will post my results. I’m pretty impressed so far though
Andy
