Home Forums Printing Discussions General Printing Topics Rolling up vinyl tricks and tips
  • Rolling up vinyl tricks and tips
    Posted by Simon Worrall on 16 January 2012 at 03:12
    Has anyone got any tips on starting to roll 1370 vinyl onto a core so it doesnt track off to the left or right as you are rolling it!!!??
    Similarly, the take up roller on the printer., I find after a few meters it always starts to bunch off to one side. Theres got to be a way that ALWAYS works. Anyone?
    Exasperated
    Simon. (hot)
    Martin Pearson replied 13 years, 9 months ago 3 Members · 6 Replies
  • Ian Johnston
    16 January 2012 at 08:15
    only use one piece of tape to hold it on to the core, in the middle of the vinyl,
  • Simon Worrall
    17 January 2012 at 08:10
    Thanks Ian.
    I do that already. I check and double check that it is straight, line the edge with the roll, pull it tight away from the rollers, in fact everything to get it straight. Only then do I tape it. One single piece in the middle.
    But it always goes off to one side.
  • Ian Johnston
    17 January 2012 at 08:51
    how big a piece?, if you use a piece of 12mm masking tape it will hinge on that point, you can easily straighten it up
    17 January 2012 at 16:17
    I use one bit of tape in the middle same as Ian, I normally run the bit I want to roll up along the edge of the bench so i know I have a straight edge to work with & when I start to roll it up I find it easier not to try & roll it to tight to start with. Once I have some turns on the tube if I need to tighten it up I turn the tube in the middle if you see what I mean. Always found it more likely to try and wander off if I tried to wind it to tight to start with.
  • Simon Worrall
    19 January 2012 at 19:41
    How do they do it at the supplier? I guess they have motorised spindles, but there must be a technique to start it off straight. It always arrives perfectly wound and tight.
    20 January 2012 at 01:24
    Your right Simon, the suppliers use equipment with motorised spindles for selling part rolls & slitting full rolls down to smaller sizes.
