Home Forums Vinyl Cutter Discussions Roland Cutters Roland VP540 + Versaworks help please?
  • Roland VP540 + Versaworks help please?
    Posted by Jonathan feeney on 30 April 2017 at 16:06
    Hi folks ,im looking for some help ,I’ve just bought a Roland VP540 I cant seem to contour cut with it ,I use corel x6 to design is there anything I need to in corel before I send to versaworks
    Jonathan feeney replied 8 years, 7 months ago 4 Members · 10 Replies
  • 10 Replies
  • Chris Wilson
    30 April 2017 at 16:27
    Hi Jon,
    Yea mate you need to set up the colour chart to have one as perf and one as contour. Should be a few YouTube videos on this. I believe you can set it to whatever you want but ours is 100% magenta. You can added it to your colour palette on screen and right click the text/object.
    We found this though which I think is a Corel problem. Versa works try’s to crop the image/whatever just a bit to much. Meaning if it’s a square you have 3 sides of it cut and one missing. We not add a extra square/box hairline just bigger than what we are cutting, making sure it has no colour/white and group it with the print/cut.
  • Shawn Bentley
    30 April 2017 at 18:00
    This should help.
    This is onCorel X5
  • Joe Wigzell
    2 May 2017 at 10:14
    If you get one line of a box missing in RVW (and you’re using .eps) just go to the Queue settings for the queue you’re using and under the ‘File Format’ tab add an eps margin – 0.35 should do the trick.
  • Chris Wilson
    2 May 2017 at 16:28
    quote Joe Wigzell:
    Thanks joe. I’ll go try that. Everyone else I’ve mentioned it to has just shrugged. Cheers
  • Joe Wigzell
    2 May 2017 at 16:41
    No probs. With eps the file format sometimes doesn’t export/show all of the information on it’s border, so when you have a spot colour (cutline in this case) it sometimes doesn’t see it. So you add a margin so that it will look a little outside of the usual boundary. Hopefully it’ll be what you were after! Can also affect the out-most point of circles etc.
  • Jonathan feeney
    2 May 2017 at 16:43
    Thanks for the help im still struggling to get the printer cutting arrrgghhhh
  • Joe Wigzell
    2 May 2017 at 16:46
    Does RVW recognise the cutline at all? You can check by looking in the middle pane of the mainscreen, where it says ‘special items’, when you select the job it should have a blue A here.
  • Jonathan feeney
    2 May 2017 at 16:47
    I’ll have a look when im back at the computer and let you know
  • Shawn Bentley
    2 May 2017 at 16:49
    Hi Jonathan pm me your number may be easier
  • Jonathan feeney
    4 May 2017 at 15:46
    Hi guys thanks for all the help I got it contour cutting at last lol cheers
