Home Forums Vinyl Cutter Discussions Roland Cutters Roland vp300
  • Roland vp300
    Posted by Stuart Davies on 26 June 2013 at 13:48
    Hi Guys
    Hope you are all well.
    most of you will be at fespa by now but for those of you that arnt perhaps you can help me out.
    I have just printed 2x 8 foot x 9 inch signs both on the same piece of vinyl,only trouble is that the roland vp300 keeps feeding vinyl through after the printed area.so far it has sent out about 10 foot.I have paused the job and phoned Roland for help (3 hours ago ).Still waiting for call back anyone else had this problem
    Stuart
    Stuart Davies replied 12 years, 6 months ago 3 Members · 4 Replies
  • Mike Grant
    26 June 2013 at 14:34
    Just cancel the job after the print is finished. Simples.
    It has probably got a wayward bit of artwork coloured white that it is picking up. I have had that problem, just go back to your original artwork and look for it.
  • Stuart Davies
    26 June 2013 at 17:24
    Thanks mike
    If i cancel the job will i be able to go back a cut the file out
    stu
    26 June 2013 at 17:38
    if you canceled the job on the machine and you have no reg marks and as long as you used the eye to set the front edge and have not released the rollers
    press set up and it will return to its origin then you can send cut data only.
    lets face it the job is stuffed that might work it has for me in the past.
  • Stuart Davies
    26 June 2013 at 20:19
    Ok guys thanks for the help
    stu
