Roland VP 540 Cutting being off
HI.
Just experienced a small problem with the printed yesterday, had few issues like it before but always manage to correct but since yesterday whatever I try does not seem to work, so I am not sure if I am missing anything.
I print stickers using custom roll, so approx 1340 x 150 mm print and cut and repeat and repeat the process.
So since yesterday, I my cut is little off so right side of machine cut is more to the right of a sticker in scan direction
Middle in the print is correct
Left side of a printer cut is more to the left side of a print.I did clean yesterday encoder strip with IPA, and will give a rollers a clean today as well, but it does not seem like its a problem down to rollers as its in a scan direction that I am not too happy with.
I am not sure if wort to order new rollers and getting them replaced and possibly a brand new encoder ? but they are nearly 200£ so would rather try other possibilities before I fork cash on it.
I did look into service mode If I can correct some stuff but not much I can find that could correct it, also to note when I did a print and cut test print (3 squares) they are also slightly off like mentioned with the prints above, is there any setting that I could correct each square individually instead of as a whole ?
Any ideas guys ?
