Home › Forums › Sign Making Discussions › General Sign Topics › Roland, Versaworks Software, tiling question. Advice please?
Posted by Jonathan feeney on 5 March 2019 at 23:40Right here goes …
I have a large wall mural at 6m x 1400 its been tiled in versaworks to 5 drops i have added 20mn overlap to top left but im slightly stumped as to how it works when installing the graphic do we start from the far left section and go right it start on the right and go left ?
Can anyone shed some light on this ?
Chris Wilson replied 6 years, 10 months ago 4 Members · 9 Replies -
I don’t think it matters.
As either the left hand edge of the drop overlaps the right hand edge of the drop you’ve fitted or vice versa. The right hand edge of the drop, overlaps the left hand edge you’ve fitted.
We usually check alignment on the bench before we fit, and Mark the overlaps with pencil top & bottom to help with fitting.
Only your preference for direction, unless you have to consider something like eye line or direction of footfall so that the ‘open edge’ is facing a certain way.
Hope it went well! -
Nice Job well done :claps:
Not easy being gloss with those spot lights, it would show any blemishes. :thumbsup:
It wasn’t easy as it was mdf i was going on to we used avery mpi2006 hi tack and it done the trick in hindsight i should have used matt ,i didn’t joe but it put me right in the mood for it [emoji23]
Trouble with Matt is they’ll probably be wiping it down, with the oil spitting on it. Matt will just streak.
quote Jonathan feeney:It wasn’t easy as it was mdf i was going on to we used avery mpi2006 hi tack and it done the trick in hindsight i should have used matt ,i didn’t joe but it put me right in the mood for it [emoji23]
In the past we have laminated this a polymeric matt laminate and it’s come up great. Typically a no no as everything should match but so far so good for us lifespan wise
