Home Forums Vinyl Cutter Discussions Roland Cutters Roland Versa Camm 540: Wont make a cut line, need help
  • Roland Versa Camm 540: Wont make a cut line, need help
    Posted by frazierx on 28 August 2007 at 15:06
    When using a illustrator file with a placed image, a transparent psd file, the software wont recognize the cut line. take out the image and it works. File is not corrupt used other images to try and see if that was issue. anyone got any ideas.
    Chris Wool replied 18 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
    28 August 2007 at 15:11
    to who ever you are.
    it might be layered
    me
  • frazierx
    28 August 2007 at 15:14
    If I flatten it I will have the white background in the file, which I dont want. EPS files with transparentcy on it is not clean enough… What options do you have for me…
    Its MIchael Frazier byt the way.
    thanks Chris.
    quote Chris Wool:
    it might be layered
    me
    28 August 2007 at 15:32
    i meant that the cut path is on another layer the fact the bitmap is layered but sits in one layer in ills.
    clear as mud.
  • frazierx
    28 August 2007 at 15:53
    I see I see. Ok tried it and still nothing. arrgg.
    quote Chris Wool:
    clear as mud.
    28 August 2007 at 17:36
    i use transparent tiffs and a cut path within corel seams to work ok.
    are you using versa or colour rip
  • frazierx
    28 August 2007 at 17:38
    Versa. Whats Colour rip…? I use plain .psd files transparent. never get the cut lines to look all that hot.always have a small bit of white somewhere.
    quote Chris Wool:
    28 August 2007 at 17:48
    versa works is a later rip to colour rip.
    does the cut path show up on the versa preview screen
