Home Forums Vinyl Cutter Discussions Roland Cutters Roland SP540V Cutting problems
  • Roland SP540V Cutting problems
    Posted by Mike Thornley on 27 March 2017 at 09:01
    We had our machine serviced in November and since then it has not cut accurately, when doing print, laminate and then putting back in the machine for labels etc
    The cuts are not running off, but move about 5mm down the sheet. The machine is finding the reg marks ok.
    Anyone ideas on what the problem with the machine might be.
    Also anyone recommend an independent Roland engineer, located in the Midlands, North
    Kevin Mahoney replied 8 years, 9 months ago 3 Members · 3 Replies
  • Philip Houston
    27 March 2017 at 09:30
    Hi Mike,
    I had the very same problem when my versacamm was first installed.
    Always out the same amount on the cut run.
    They sent me out an engineer who asked me to show him how I was doing it.
    My method was correct but still off.
    10 mins later he packed up his case and left.
    He followed the call out with a hefty bill.
    It was obviously some tweeking needed in the settings.
    I ran the supplier who dropped the charge!
    I know I haven’t answered your question, but at least
    it won’t be a serious fix.
    Good luck.
  • John young
    27 March 2017 at 17:00
    Hi there
    Call Andy Malcolm who is an engineer and knows all the problem solutions on these machines.
    His number is 07921 380282
    Hope this helps you out
  • Kevin Mahoney
    27 March 2017 at 19:07
    There are print & cut alignment settings in the control panel on the machine if you haven’t tried that already, we have a couple of sp540v machines & have had this issue once or twice in the past, might be worth a try. Will second the Andy Malcolm recommendation, not much he doesn’t know about Roland printers, he may even talk you through the steps over the phone. He’s looked after all of my machines for 14 years, great guy
