Home Forums Vinyl Cutter Discussions Roland Cutters roland sp300 not printing
  • roland sp300 not printing
    Posted by chris third on 19 April 2009 at 05:28
    need help with sp300.
    moved it to new office, head bracket in place,didnt remove the inks,
    moved it with care,anyway
    looks like the heads are not dropping down to print on the vinyl.
    test cut s ok, test print it goes through the motions but no print???
    versaworks sends the print ok but as i said goes through the motions but no print??
    any ideas??
    😕 [/b]
    chris third replied 16 years, 8 months ago 4 Members · 6 Replies
  • Andrew Blackett
    19 April 2009 at 07:19
    Hi Chris,
    Is the machine getting data and moving the head side to side to print, or is it just sat in the docking area doing nothing.
    If its the first maybe try a couple of head cleans, if its not doing anything I’d imagine its a connection problem, can you "verify" the machine from versaworks (it’ll tell you if the machine is reachable)
    Andy
  • chris third
    19 April 2009 at 11:52
    yer it moves like its printing,but as i look under the head it isn’t toughing the vinyl surface
    versaworks says all s good ,sends data ok??cleans heads ok.
    would it have to do with the reset hole near the ink plug bottle??
    i think i may have pushed it up thinking it had to do with moving the unit.
  • Andrew Blackett
    19 April 2009 at 13:03
    The head doesnt actually touch the service mate just flys over it.
    Try doing a test print from the button on the front panel, you should get four dotted bands (one for each colour) if you dont then theres something far deeper than just a head clean. If its patchy or theres odd bits missing then try a manual clean.
    Andy
    19 April 2009 at 14:50
    quote :
    please explain more
  • Gary Birch
    19 April 2009 at 18:56
    Sounds to me like you have an air block in the ink pipes, try doing a couple of powerful cleans, we had the same issue when we moved recently.
    Gary
  • chris third
    20 April 2009 at 09:46
    thanks to all u guys for the quick response.
    gave it a power clean, away she went.
    buy you all a beer or 2
    till next problem,thanks
